Lunatik650
Mar 18, 2022Follower
R6700v3 nighthawk app login timing out
Everytime I try to login in to setup the app it asks me for login credentials for admin. I enter the password and it says it has times out and asks to reboot my phone. I have rebooted my phone and uninstalled and reinstalled the app. I encounter the same error everytime. I am able to login on my laptop to through routerlogin.net and my phone is connected to the correct wifi network. please help.
- DarrenMSr. NETGEAR Moderator
Hello Lunatik650
When you get the timeout issue in the app shake your phone back and forth a bug report should pop up and this will send the issue to our app team to investigate.
DarrenM
- VicteryAspirant
Thank You for the info.it was very helpful. I just sent the bug report to tech. Hopefully the fix is coming soon. ( I Hope ) 🙂
- rronnerAspirant
I am having the same issue running firmware V1.0.4.128_10.0.104
- ldogg1981AspirantAny update on this because I still have the exact same problem and it has been this way for at least a year? It worked when I first installed the router and then Netgear broke the app a few months later.
- Mingsr912AspirantHello, im also having this issue. Anyone find a solution to this? I'm using an android samsung note 20, and my router is a 6700v3 nighthawk. Both are update to date on firmware. And I can access it through a web browser. Just not able to use the app for turning on and off wifi on kids ipad purpose.
