Bob0077
Sep 23, 2016Tutor
r7000 AC 1900 Smart Wifi router blocks Outlook from connecting to the outgoing smtp server
After many hours of work by level 2 technicians at Cox (my ISP) and Microsoft it has been resolved that my r7000 wireless router is blocking Outlook from connecting to the outgoing smtp mail server. ...
Retired_Member
Sep 23, 2016any chance the IP is being blocked for some reason, try using old laptop WAN Mac in router setup...internet setup select use pc mac
- DexterJBSep 25, 2016NETGEAR Moderator
Hi Bob0077,
1. Please provide me the following information:
Outgoing Server:
Outgoing Port:
2. Are you using the Outlook client or webmail?
3. Can you send out an email on your phone using mobile data?
4. Have you tried using the old laptop through the router?
Dexter
Community Team
- DexterJBSep 29, 2016NETGEAR Moderator
Hi Bob0077,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- PonyskiOct 08, 2016Aspirant
I am having the same issue, did anyone resolve this issue?
