ARMD
May 08, 2022Aspirant
r7000 anywhere access
I have been unable to locate anywhere access on my netgear r7000 router. under webservices management no option for remote access is found. the only option is to check use https.
i reformated router back to factory settings and reinstalled my backup and i had access remotely using nighthawk app but it stopped. again no option for remote access noted when logging into netgear from my computer.
any suggestions.
Try disabling Anywhere Access by selecting the cloud in the circle icon on the Nighthawk mobile app, select Settings, then select Anywhere Access. Slide the button to disable this feature. Then check and see if local access is seen in the Your Products list as a Local Connection.
- ARMDAspirant
the nighthawk app will not even let me sign in. all it tells me is it timed out. i have no issues logging into router from a web browser with the same credentials
- ARMDAspirant
i have same issue. no remote access under web services and nighthawk app will not connect to my R7000. would be nice to hear a response from netgear to let us know what is going on
