kg706's avatar
kg706
Follower
Oct 09, 2020
R7000 Nighthawk app doesn't trust my device
I am trying to set up the Nighthawk app on my iphone. To establish connection, it must verify the device, which the first method, using a push notification, doesn't work. The push notification doesn't ever arrive. The second method is to send an email, which also doesn't work. I get the verification code in my email but the app refuses to trust the iphone device. Is anyone else having these issues? How did you resolve it?
  • I had this problem also, it’s so frustrating! This option is one of the reasons I purchased this router. Also, this is my third router. I’ve had 2 of the r7000. The first one quit working altogether and the second one started failing. I bought a newer one last week hoping that this one would be great and the actual router works but now the app is faulty. Can’t win for losing!!
  • I am having the same problem!!!
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello,
    For those experiencing this issue, may you check to see if there is a firmware update available, reinstall the Nighthawk app, and enable local network access. If your issue persists, please send me a private message with the following info for us to check further.
    Email:
    Serial Number:
    Firmware Version:
    Nighthawk App Version: (iOS or Android)
    Thanks,
    Christian
