Mrfix71
Jan 24, 2025Aspirant
R7000 "No Internet Connection" in App
Similar ISP setup and situation to: https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/R7000-Nighthawk-No-Internet-Connection/m-p/2221698#M215680 Tried all the solutions on: https://kb....
Mrfix71
Quick update....
Someone just loaned me an old mesh system of theirs to try, a MR-60 router and two MS-60 satellites. They upgraded to an Orbi setup in their shop. Using the Nighthawk app, I was able to get to the point where i would connect to the Nighthawk WiFi. However, my phone would not connect, saying I was entering the incorrect password. Odd because it automatically entered a password for me and copying the shown password from the app then pasting it manually resulted in the same "Could Not Connect - Incorrect password" message. Nighthawk app still says to tap on "Wifi is Connected" without being able to go back, which exits me from the app.
Incorrect password but it is the password given to me by the Nighthawk app, copied and pasted using the prompts in the app. What gives?????
Not at all impressed and am quite disgusted with this whole Nighthawk thing.
Jan 24, 2025Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
