Mrfix71
Jan 24, 2025Aspirant
R7000 "No Internet Connection" in App
Similar ISP setup and situation to: https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/R7000-Nighthawk-No-Internet-Connection/m-p/2221698#M215680 Tried all the solutions on: https://kb....
Mrfix71
UPDATE.....
After a long and confusing call with Tech Support, we were able to get mesh system and the Nighthawk app functioning. Not clear on what the issue was, but the prompts on the app did not accurately match my situation.
New mesh system should be much easier to set up after I choose what size of coverage I will need to buy.
Feb 04, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
