MikeLorena
Nov 12, 2017Tutor
R7000, Printer not being found in Selection list
We have a NightHawk R7000. our HP laptop, Win10, my printer shows in the NETGEAR USB Control Center but not when I go to print (Word, Excel, PDF, etc.) Any thoughts? Lorea
michaelkenward
Nov 13, 2017Guru - Experienced User
Can you print with the device connected to a USB port on the PC?
I ask because the same thing came up here recently:
Re: WNDR4300V2 Router recognizes the HP printer bu... - NETGEAR Communities
If the printer won't work on a PC, it won't work on a router.
- MikeLorenaNov 14, 2017TutorYes, it works fine... It actually works on 2 other HP laptops, just not mine. thx for the help. Lorena
- CChrisNov 14, 2017Aspirant
I'm having the same issue along with my Nest losing wireless connectivity.
I do use access control which i turned off with no difference. What I have noticed though is under access control those two devices (Printer/Nest) don't have an IP address. I have assigned a static address to it and that doesn't work either.
I have upgraded to the latest firmware and completed a factory reset, manually setting it up and no change. Rebooting the router allowes it to connect for a short time. Wired/Wireless(w/SSID name) connections have no issues.
- DexterJBNov 22, 2017NETGEAR Moderator
Hi CChris,
1. What is the model number and firmware version of the router?
2. Have you tried changing the wireless channel of the router?
3. You can try using address reservation. The steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/24091
Dexter
Community Team
Hi MikeLorena,
1. If it is a network printer (connects via WiFi or Ethernet) then the USB Control Center is no longer required.
2. Please try re-installing the printer drivers on the computer that is experiencing the issue.
Dexter
Community Team
- MikeLorenaNov 30, 2017Tutor
Thx Dexter,
No ,the printer is plugged in to the USB port on the router.
I tried updating the firmware, than my router stopped working completly. So, I restored the firmware.
2/3 ofour HP laptops work fine. The prointer shows up oin ReadyShare, we just cant get Win10 to find it (scan) for using in Adobe/Word, etc.
thx, Lorena
