Prashantverma
Dec 29, 2018Aspirant
R7000 VPN
Hi I am having trouble using VPN featue.
As instructed i created an DNS account with noip and activated taht in R7000 router which stats as successfully updated. I have also enabled VPN and copied the confirg files for windows in the program files opevn vpn config folder.
But while connetng VPN i get below logs:
If any one could help and see if i have missed or done something wrong.
Sat Dec 29 13:11:46 2018 us=121059 Current Parameter Settings:
Sat Dec 29 13:11:46 2018 us=121059 config = 'client2.ovpn'
Sat Dec 29 13:11:46 2018 us=121059 mode = 0
Sat Dec 29 13:11:46 2018 us=121059 show_ciphers = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 show_digests = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 show_engines = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 genkey = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 key_pass_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 show_tls_ciphers = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 connect_retry_max = 0
Sat Dec 29 13:11:46 2018 us=121059 Connection profiles [0]:
Sat Dec 29 13:11:46 2018 us=121059 proto = udp
Sat Dec 29 13:11:46 2018 us=121059 local = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 local_port = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 remote = 'ea2.ddns.net'
Sat Dec 29 13:11:46 2018 us=121059 remote_port = '12974'
Sat Dec 29 13:11:46 2018 us=121059 remote_float = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 bind_defined = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 bind_local = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 bind_ipv6_only = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 connect_retry_seconds = 5
Sat Dec 29 13:11:46 2018 us=121059 connect_timeout = 120
Sat Dec 29 13:11:46 2018 us=121059 socks_proxy_server = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 socks_proxy_port = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 tun_mtu = 1500
Sat Dec 29 13:11:46 2018 us=121059 tun_mtu_defined = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 link_mtu = 1500
Sat Dec 29 13:11:46 2018 us=121059 link_mtu_defined = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 tun_mtu_extra = 32
Sat Dec 29 13:11:46 2018 us=121059 tun_mtu_extra_defined = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 mtu_discover_type = -1
Sat Dec 29 13:11:46 2018 us=121059 fragment = 0
Sat Dec 29 13:11:46 2018 us=121059 mssfix = 1450
Sat Dec 29 13:11:46 2018 us=121059 explicit_exit_notification = 0
Sat Dec 29 13:11:46 2018 us=121059 Connection profiles END
Sat Dec 29 13:11:46 2018 us=121059 remote_random = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 ipchange = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 dev = 'tap'
Sat Dec 29 13:11:46 2018 us=121059 dev_type = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 dev_node = 'NETGEAR-VPN'
Sat Dec 29 13:11:46 2018 us=121059 lladdr = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 topology = 1
Sat Dec 29 13:11:46 2018 us=121059 ifconfig_local = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 ifconfig_remote_netmask = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 ifconfig_noexec = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 ifconfig_nowarn = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 ifconfig_ipv6_local = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 ifconfig_ipv6_netbits = 0
Sat Dec 29 13:11:46 2018 us=121059 ifconfig_ipv6_remote = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 shaper = 0
Sat Dec 29 13:11:46 2018 us=121059 mtu_test = 0
Sat Dec 29 13:11:46 2018 us=121059 mlock = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 keepalive_ping = 0
Sat Dec 29 13:11:46 2018 us=121059 keepalive_timeout = 0
Sat Dec 29 13:11:46 2018 us=121059 inactivity_timeout = 0
Sat Dec 29 13:11:46 2018 us=121059 ping_send_timeout = 0
Sat Dec 29 13:11:46 2018 us=121059 ping_rec_timeout = 0
Sat Dec 29 13:11:46 2018 us=121059 ping_rec_timeout_action = 0
Sat Dec 29 13:11:46 2018 us=121059 ping_timer_remote = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 remap_sigusr1 = 0
Sat Dec 29 13:11:46 2018 us=121059 persist_tun = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 persist_local_ip = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 persist_remote_ip = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 persist_key = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 passtos = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 resolve_retry_seconds = 1000000000
Sat Dec 29 13:11:46 2018 us=121059 resolve_in_advance = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 username = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 groupname = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 chroot_dir = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 cd_dir = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 writepid = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 up_script = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 down_script = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 down_pre = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 up_restart = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 up_delay = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 daemon = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 inetd = 0
Sat Dec 29 13:11:46 2018 us=121059 log = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 suppress_timestamps = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 machine_readable_output = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 nice = 0
Sat Dec 29 13:11:46 2018 us=121059 verbosity = 5
Sat Dec 29 13:11:46 2018 us=121059 mute = 0
Sat Dec 29 13:11:46 2018 us=121059 gremlin = 0
Sat Dec 29 13:11:46 2018 us=121059 status_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 status_file_version = 1
Sat Dec 29 13:11:46 2018 us=121059 status_file_update_freq = 60
Sat Dec 29 13:11:46 2018 us=121059 occ = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 rcvbuf = 0
Sat Dec 29 13:11:46 2018 us=121059 sndbuf = 0
Sat Dec 29 13:11:46 2018 us=121059 sockflags = 0
Sat Dec 29 13:11:46 2018 us=121059 fast_io = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 comp.alg = 2
Sat Dec 29 13:11:46 2018 us=121059 comp.flags = 1
Sat Dec 29 13:11:46 2018 us=121059 route_script = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 route_default_gateway = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 route_default_metric = 0
Sat Dec 29 13:11:46 2018 us=121059 route_noexec = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 route_delay = 5
Sat Dec 29 13:11:46 2018 us=121059 route_delay_window = 30
Sat Dec 29 13:11:46 2018 us=121059 route_delay_defined = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 route_nopull = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 route_gateway_via_dhcp = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 allow_pull_fqdn = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 management_addr = '127.0.0.1'
Sat Dec 29 13:11:46 2018 us=121059 management_port = '25341'
Sat Dec 29 13:11:46 2018 us=121059 management_user_pass = 'stdin'
Sat Dec 29 13:11:46 2018 us=121059 management_log_history_cache = 250
Sat Dec 29 13:11:46 2018 us=121059 management_echo_buffer_size = 100
Sat Dec 29 13:11:46 2018 us=121059 management_write_peer_info_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 management_client_user = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 management_client_group = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 management_flags = 4102
Sat Dec 29 13:11:46 2018 us=121059 shared_secret_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 key_direction = 0
Sat Dec 29 13:11:46 2018 us=121059 ciphername = 'AES-128-CBC'
Sat Dec 29 13:11:46 2018 us=121059 authname = 'SHA1'
Sat Dec 29 13:11:46 2018 us=121059 prng_hash = 'SHA1'
Sat Dec 29 13:11:46 2018 us=121059 prng_nonce_secret_len = 16
Sat Dec 29 13:11:46 2018 us=121059 keysize = 0
Sat Dec 29 13:11:46 2018 us=121059 engine = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 replay = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 mute_replay_warnings = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 replay_window = 64
Sat Dec 29 13:11:46 2018 us=121059 replay_time = 15
Sat Dec 29 13:11:46 2018 us=121059 packet_id_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 use_iv = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 test_crypto = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 tls_server = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 tls_client = ENABLED
Sat Dec 29 13:11:46 2018 us=121059 key_method = 2
Sat Dec 29 13:11:46 2018 us=121059 ca_file = 'ca.crt'
Sat Dec 29 13:11:46 2018 us=121059 ca_path = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 dh_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 cert_file = 'client.crt'
Sat Dec 29 13:11:46 2018 us=121059 extra_certs_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 priv_key_file = 'client.key'
Sat Dec 29 13:11:46 2018 us=121059 pkcs12_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 cryptoapi_cert = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 cipher_list = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 tls_verify = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 tls_export_cert = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 verify_x509_type = 0
Sat Dec 29 13:11:46 2018 us=121059 verify_x509_name = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 crl_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 ns_cert_type = 0
Sat Dec 29 13:11:46 2018 us=121059 remote_cert_ku[i] = 0
Sat Dec 29 13:11:46 2018 us=121059 remote_cert_eku = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 ssl_flags = 0
Sat Dec 29 13:11:46 2018 us=121059 tls_timeout = 2
Sat Dec 29 13:11:46 2018 us=121059 renegotiate_bytes = -1
Sat Dec 29 13:11:46 2018 us=121059 renegotiate_packets = 0
Sat Dec 29 13:11:46 2018 us=121059 renegotiate_seconds = 3600
Sat Dec 29 13:11:46 2018 us=121059 handshake_window = 60
Sat Dec 29 13:11:46 2018 us=121059 transition_window = 3600
Sat Dec 29 13:11:46 2018 us=121059 single_session = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 push_peer_info = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 tls_exit = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 tls_auth_file = '[UNDEF]'
1 Reply
- PrashantvermaAspirant
Sat Dec 29 13:11:46 2018 us=121059 tls_crypt_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=121059 pkcs11_protected_authentication = DISABLED
Sat Dec 29 13:11:46 2018 us=121059 pkcs11_private_mode = 00000000
Sat Dec 29 13:11:46 2018 us=121059 pkcs11_cert_private = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 pkcs11_cert_private = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 pkcs11_pin_cache_period = -1
Sat Dec 29 13:11:46 2018 us=126057 pkcs11_id = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 pkcs11_id_management = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 server_network = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 server_netmask = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 server_network_ipv6 = ::
Sat Dec 29 13:11:46 2018 us=126057 server_netbits_ipv6 = 0
Sat Dec 29 13:11:46 2018 us=126057 server_bridge_ip = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 server_bridge_netmask = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 server_bridge_pool_start = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 server_bridge_pool_end = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_pool_defined = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_pool_start = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_pool_end = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_pool_netmask = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_pool_persist_filename = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_pool_persist_refresh_freq = 600
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_ipv6_pool_defined = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_ipv6_pool_base = ::
Sat Dec 29 13:11:46 2018 us=126057 ifconfig_ipv6_pool_netbits = 0
Sat Dec 29 13:11:46 2018 us=126057 n_bcast_buf = 256
Sat Dec 29 13:11:46 2018 us=126057 tcp_queue_limit = 64
Sat Dec 29 13:11:46 2018 us=126057 real_hash_size = 256
Sat Dec 29 13:11:46 2018 us=126057 virtual_hash_size = 256
Sat Dec 29 13:11:46 2018 us=126057 client_connect_script = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 learn_address_script = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 client_disconnect_script = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 client_config_dir = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 ccd_exclusive = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 tmp_dir = 'C:\Users\Admin\AppData\Local\Temp\'
Sat Dec 29 13:11:46 2018 us=126057 push_ifconfig_defined = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 push_ifconfig_local = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 push_ifconfig_remote_netmask = 0.0.0.0
Sat Dec 29 13:11:46 2018 us=126057 push_ifconfig_ipv6_defined = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 push_ifconfig_ipv6_local = ::/0
Sat Dec 29 13:11:46 2018 us=126057 push_ifconfig_ipv6_remote = ::
Sat Dec 29 13:11:46 2018 us=126057 enable_c2c = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 duplicate_cn = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 cf_max = 0
Sat Dec 29 13:11:46 2018 us=126057 cf_per = 0
Sat Dec 29 13:11:46 2018 us=126057 max_clients = 1024
Sat Dec 29 13:11:46 2018 us=126057 max_routes_per_client = 256
Sat Dec 29 13:11:46 2018 us=126057 auth_user_pass_verify_script = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 auth_user_pass_verify_script_via_file = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 auth_token_generate = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 auth_token_lifetime = 0
Sat Dec 29 13:11:46 2018 us=126057 client = ENABLED
Sat Dec 29 13:11:46 2018 us=126057 pull = ENABLED
Sat Dec 29 13:11:46 2018 us=126057 auth_user_pass_file = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 show_net_up = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 route_method = 3
Sat Dec 29 13:11:46 2018 us=126057 block_outside_dns = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 ip_win32_defined = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 ip_win32_type = 3
Sat Dec 29 13:11:46 2018 us=126057 dhcp_masq_offset = 0
Sat Dec 29 13:11:46 2018 us=126057 dhcp_lease_time = 31536000
Sat Dec 29 13:11:46 2018 us=126057 tap_sleep = 0
Sat Dec 29 13:11:46 2018 us=126057 dhcp_options = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 dhcp_renew = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 dhcp_pre_release = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 dhcp_release = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 domain = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 netbios_scope = '[UNDEF]'
Sat Dec 29 13:11:46 2018 us=126057 netbios_node_type = 0
Sat Dec 29 13:11:46 2018 us=126057 disable_nbt = DISABLED
Sat Dec 29 13:11:46 2018 us=126057 OpenVPN 2.4_beta1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Nov 17 2016
Sat Dec 29 13:11:46 2018 us=126057 Windows version 6.2 (Windows 8 or greater) 64bit
Sat Dec 29 13:11:46 2018 us=126057 library versions: OpenSSL 1.0.2i 22 Sep 2016, LZO 2.09
Enter Management Password:
Sat Dec 29 13:11:46 2018 us=126057 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341
Sat Dec 29 13:11:46 2018 us=126057 Need hold release from management interface, waiting...
Sat Dec 29 13:11:46 2018 us=551040 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341
Sat Dec 29 13:11:46 2018 us=656083 MANAGEMENT: CMD 'state on'
Sat Dec 29 13:11:46 2018 us=656083 MANAGEMENT: CMD 'log all on'
Sat Dec 29 13:11:46 2018 us=851028 MANAGEMENT: CMD 'hold off'
Sat Dec 29 13:11:46 2018 us=851028 MANAGEMENT: CMD 'hold release'
Sat Dec 29 13:11:46 2018 us=896028 MANAGEMENT: CMD 'proxy NONE '
Sat Dec 29 13:11:47 2018 us=896255 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Dec 29 13:11:48 2018 us=326354 LZO compression initializing
Sat Dec 29 13:11:48 2018 us=351401 Control Channel MTU parms [ L:1654 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Sat Dec 29 13:11:48 2018 us=351401 MANAGEMENT: >STATE:1546089108,RESOLVE,,,,,,
Sat Dec 29 13:11:48 2018 us=681341 Data Channel MTU parms [ L:1654 D:1450 EF:122 EB:411 ET:32 EL:3 ]
Sat Dec 29 13:11:48 2018 us=681341 Local Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Sat Dec 29 13:11:48 2018 us=681341 Expected Remote Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Sat Dec 29 13:11:48 2018 us=681341 TCP/UDP: Preserving recently used remote address: [AF_INET](My External IP: UDP)
Sat Dec 29 13:11:48 2018 us=681341 Socket Buffers: R=[65536->65536] S=[65536->65536]
Sat Dec 29 13:11:48 2018 us=681341 UDP link local: (not bound)
Sat Dec 29 13:11:48 2018 us=681341 UDP link remote: [AF_INET]94.11.186.103:12974
Sat Dec 29 13:11:48 2018 us=681341 MANAGEMENT: >STATE:1546089108,WAIT,,,,,,
Sat Dec 29 13:12:48 2018 us=520965 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Dec 29 13:12:48 2018 us=520965 TLS Error: TLS handshake failed
Sat Dec 29 13:12:48 2018 us=520965 TCP/UDP: Closing socket
Sat Dec 29 13:12:48 2018 us=520965 SIGUSR1[soft,tls-error] received, process restarting
Sat Dec 29 13:12:48 2018 us=520965 MANAGEMENT: >STATE:1546089168,RECONNECTING,tls-error,,,,,
Sat Dec 29 13:12:48 2018 us=520965 Restart pause, 5 second(s)
Sat Dec 29 13:12:53 2018 us=526566 MANAGEMENT: CMD 'proxy NONE '
Sat Dec 29 13:12:54 2018 us=526704 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Dec 29 13:12:54 2018 us=526704 Re-using SSL/TLS context
Sat Dec 29 13:12:54 2018 us=526704 LZO compression initializing
Sat Dec 29 13:12:54 2018 us=526704 Control Channel MTU parms [ L:1654 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Sat Dec 29 13:12:54 2018 us=526704 MANAGEMENT: >STATE:1546089174,RESOLVE,,,,,,
