akella
Sep 01, 2020Initiate
R7400 parental controls
I am unable to see the parental control button on the Nighthawk app or on the routerlogin using my web. I am also unable to block websites like roblox and discord using the block sites function. This...
michaelkenward
Sep 05, 2020Guru - Experienced User
They removed access to parental controls from the Nighthawk app. They'd rather you used the paid for Circle alternative.
I see no sign in the manual that the R7400 supports parental controls. Did they add it with new firmware?
If so, you can still use a desktop and the Desktop genie to do this.
Or you can use your account to login to opendns.
That should work on your mobile.
How do I set up Live Parental Controls on my Nighthawk router? | Answer | NETGEAR Support
