aes32752
Jul 09, 2023Follower
R7400
I am the second owner and can not re-register product info. Netgear computer keeps telling me I am not the registered owner.
michaelkenward
Jul 10, 2023Guru - Experienced User
Why are you trying to register? What do you want to do?
Registration for support and warranty does not transfer.
NETGEAR Product Registration FAQ | Answer | NETGEAR Support
So, back to what you are trying to do?
By the way, the first thing you should do with a second-hand device is to reset it so that it forgets any settings inherited from the previous owner.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
