Smurfboy
Jun 20, 2020Follower
R7900 Hofix Problem
Nighthawk App doesn’t see the new Hotfix for my router. When I go to the Netgear website it shows the new Hotfix Version. The Nighthawk App don’t give you the option to download and install it manua...
Jun 20, 2020Guru - Experienced User
You can log in through the browser to update. I'd recommend doing it hardwired through the browser. We see the most issues when people update via the app or wireless.
- michaelkenwardJun 22, 2020Guru - Experienced User
Use a browser. Download the firmware from the support pages for the device and manually install it.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device.
The manual explains the process.
