kevinluo1990
Jun 25, 2017Tutor
R7900 update V1.0.1.18_10.0.20. cannot connect to Netgear genie
Hi guys, I recently updated Firmware to V1.0.1.18_10.0.20 for my router. But ever since I updated, I cannot login to my router via my iPhone app and desktop NetgearGenie. It says"login failed. Th...
DexterJB
Jul 13, 2017NETGEAR Moderator
Hi kevinluo1990 and eckypting,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- kevinluo1990Jul 13, 2017Tutor
Hi,
Thanks for the reply. Well, I tried but it didn't work. I downgrade the firmware version to the previous one, and everything was ok again. So I guess there is some error in V1.0.1.18?
- eckyptingJul 14, 2017Aspirant
I backed up the router configuration and did a factory reset as suggested, then restored the configuration from the backup. Once again, the the Genie App worked for one session, and then has failed to login thereafter. The Genie for Windows works intermittently, and even then only when using the remote access route to login to the router. Direct/local login using Genie for Windows does not appear to work (the attempt to login times out).
