kevinluo1990
Jun 25, 2017Tutor
R7900 update V1.0.1.18_10.0.20. cannot connect to Netgear genie
Hi guys, I recently updated Firmware to V1.0.1.18_10.0.20 for my router. But ever since I updated, I cannot login to my router via my iPhone app and desktop NetgearGenie. It says"login failed. Th...
DexterJB
Jul 13, 2017NETGEAR Moderator
Hi kevinluo1990 and eckypting,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
kevinluo1990
Jul 13, 2017Tutor
Hi,
Thanks for the reply. Well, I tried but it didn't work. I downgrade the firmware version to the previous one, and everything was ok again. So I guess there is some error in V1.0.1.18?
