leopeo
Dec 27, 2020Follower
R7900P having problems with the nighthawk app
For the past 2 days have not been able to acces the Nighthawk app.. I've re-booted the router and have even uninstalled, then re-installed the app. I kepp recieving the same response, "login failed. ...
mne
Dec 27, 2020Guide
I was having the same problem. It started after I upgraded the router firmware to V1.4.1.66. I rolled back to V1.4.1.64 and that resolved the issue.
spuppala
Dec 31, 2020Aspirant
Upgraded R7900P to new Firmware Version V1.4.1.66_1.3.26 from Nighthawk ios app and not from my desktop. Nighthawk ios app is not working. Eachtime it ask for login and login is not working. I want to rollback to older firmware version. How to rollback when i dont have any older file saved in my desktop as i upgraded the firmware from my mobile device?
- mneJan 01, 2021Guide
You can download older firmware version from https://www.netgear.com/support/product/R7900P.aspx#download ... under Firmware and Software Downloads, click on View Previous Versions and can select one of the previous versions to download.
Have you tried rebooting the router and modem? EdWONG stated that this resolved the issue. I'm away from home and heven't been able to try that.
