ghoti
Dec 03, 2021Aspirant
R7960P (AC3600) will not detect internet; another router works no problem
Moved to new home. My R7960P was working fine at old home. Now, everyting okay EXCEPT router will not detect internet. I tried a reset and powering router and computer off and on -- no joy. Tried...
Dec 04, 2021Guru - Experienced User
what modem/gateway is the router connected to?
- ghotiDec 04, 2021Aspirant
Thanks for your reply.
Connected to Spectrum cable modem. 192.168.1.1
- plemansDec 04, 2021Guru - Experienced UserWhich one?
- michaelkenwardDec 05, 2021Guru - Experienced User
That does not tell us what the modem actually is. (Spectrum makes a lot of devices.) But the 192.168.1.1 bit is a clue.
If it is the local IP address of your Spectrum cable modem that suggests that it is actually a modem/router. (Modem-only devices don't usually adopt that address.)
Your R7960P also likes to adopt that IP address. That is a sign that you have two routers on the network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support- ghotiDec 05, 2021Aspirant
Thanks for reading and reply.
I am using not just the cable company's modem, but also their router (since I can't get mine up and running). So that may account for the 192.168.1.1
Inasmuch as I was given both a modem and router, I doubt the modem has a router built in.
Spectrum Cable doesn't make it easy to find the model number on their modem and router, but I found this on the modem: ES2251; DOCSIS 3.1eMTA.
I found this on the router: WiFi6 Router; SAX1V1K
I could go on using their modem and router, but I suspect my router is better.
