bgarisn
Dec 26, 2022Tutor
R7960P Unable to connect wired OR wireless OR through app
So I have an R7960P wireless router. Ever since I've updated to the latest firmware version I have had issues connecting to the setup page.
http://routerlogin.net/start.htm
(10.0.0.1)
I get the following screen on any web browser I've used (Chrome Edge, Firefox).
I really don't understand how this can be the case when I'm wired into the router.
What could possibly be happening that keeps me from accessing the configuration page ?
I have tried connecting to this page from a wireless connection (a laptop on my network ). I get the same result. I have tried each of the different wireless networks -- 2.4 GHz, 5 GHz and Guest 2.4/5.0. all give the same result.
I have tried connecting via the nighthawk app (which is absolute garbage). and it says can't find your nighthawk. this happens when I'm connected to any of the wireless networks via my phone. I don't understand how this could be happening when all of the devices have access to the Internet.
If someone could point me in the right direction to get started I would really appreciate it. and again I just cannot understand how if I am connected to the router with an Ethernet cable why I can't access the configuration page. It's absurd.
Thanks for any and all help and if I forgot to include any relevant information, I am sorry and I will do so as soon as you tell me what I need to provide.
Sort By
Unless you changed your IP address, the router changing to the backup 10.0.0.1 address makes me suspect you're in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-ModeWhat modem is the router connected to?
are you able to access the router using its ip address?
- bgarisnTutor
Thanks for the reply and the starting point.
What modem is the router connected to? Are you able to access the router using its ip address?
I am connected to my AT&T (ISP provided) router, which I can access using its IP address (typical -- 192.168.1.254)
I have verified that the WiFi that the ATT router provides are all turned OFF. I enabled IP Passthrough and made sure that the MAC address that was used was the one for my Netgear router.
I then rebooted the ATT and Netgear devices (ATT 1st). I still seem to have IP addresses that are of the format [10.0.0.xx] I am not sure if this should be the case or not but I think from looking at the Advanced -> Setup -> LAN Setup page, I believe this is right:
Hopefully things will be better now. I will be back if they are not.
Thank you
- bgarisnTutor
Well... after even a few hours, I am still have connectivity issues with both wired / wireless and through the app (especially the app). I was even having MAJOR issues coming back to this website specifically to log in and report my results so far.
I will keep searching and if I find a solution post here, but if anyone has any other leads, I will be more than glad to follow them.
Thanks
