Tech16
Mar 27, 2017Initiate
R8000 Firmware Update R8000-V1.0.3.36_1.1.25 breaks Live Parental Controls and Genie App functions
Updating firmware on R8000 to R8000-V1.0.3.36_1.1.25.chk (latest recommended update) breaks Live Parental Controls (LPC)-cannot turn ON or OFF from web app (Gui takes you instead to NetGear page, htt...
lowman
May 13, 2017Aspirant
Did not try factory reset . The Genie will not recognise the router even after updateing to new version . I tryed disableing the IPv6 and it will default to another setting instead of disabled . Current verson firm ware after flash 1.0.3.36-1.1.25 . For some reason my Go Flex nas is not scessable thru and ftp that is on put
Ipads . The nas was giving issues before the flash and reason for flash was the usb ready share was malfunctioning the ready share was found to be a bad usb extension cable between router and storage it seems that that issue is resolved . I can acess nas thry seagate dashdoard but not the ftp on any Ipad . I can not even log in with Ipad genie it tosses the Ipv 6 thing . I am lost when it rains it pours . What version firmware should I roll router back to .
michaelkenward
May 13, 2017Guru - Experienced User
- lowmanMay 13, 2017Aspirant
Mmmm ? I think there is a port issue ? Seagate nas inascessable how do I find out what is useing port 21 suppoedly an ftp ? 22 443 and port 80"are open
- michaelkenwardMay 13, 2017Guru - Experienced User
We still don't know if you have reset.
PS It is hard to follow your messages. Thought of trying the Spellcheck button above here?
