lucynda
May 26, 2017Aspirant
R8000 Netgenie says "router does not support remote access"
Since the net genie update I have not been able to login remotely from my iphone. It says my router does not support remote access but I know this is not true as I used it remotely ALL the time with ...
May 26, 2017Guru - Experienced User
Was the routers FW updated? Is remote access enabled ON the router using the routers web page?
