lucynda
May 26, 2017Aspirant
R8000 Netgenie says "router does not support remote access"
Since the net genie update I have not been able to login remotely from my iphone. It says my router does not support remote access but I know this is not true as I used it remotely ALL the time with ...
lucynda
I updated the firmware - still didn't work. Rolled back to the firmware recommend on another post. Still nothing
Yes it's turned on in my router settings
May 26, 2017Guru - Experienced User
Try removing the app from the phone, power cycle the phone then re-install the app.
If this fails, I'd phone contact or send a ticket about this to support. Something isn't right here.
