Zazwat's avatar
Zazwat
Tutor
Jan 29, 2023
R8000 router security questions not taking
I was trying to port forward and it asked me for two security questions. I answered and it told me they were wrong so I figured I must have made a typo when I was setting up the router like 3 years ag...
  • plemans's avatar
    Jan 29, 2023
    Try a different web browser. And check your login password.
    It usually only asks for the serial number and security questions if you're getting your login wrong or didn't set it up with minimum requirements.
    Make sure to have at least 10 characters
    1 upper case
    1 lower case
    1 special character
    1 number.
