dspiatkowski
Mar 16, 2017Aspirant
R8000 V1.0.3.36_1.1.25 firmware breaks Android Genie app....
MAJOR problem with this latest firmware release is that it completely brakes the Android version of the app...so as I came to find out a few nights ago, the mobile app doesn't even manage to LOG-IN t...
Garfield18
Mar 17, 2017Guide
FYI, this also applied to the iPad and Windows version of Genie!
You should be able to still log on using the web interface. But you will not get the parental control to work from the web interface, which I am always wonder why they make a decision to only allow a person to change the parental control from the Genie, which doesn't work that well anyhow, on iPad/Android/Windows versions.
I reverse back to previous version of the firmware, I knows Windows version worked fine. iPad version seems to have issue seeing I have the parental control turned on. I haven't tried the Android version yet.
We can only wait for Netgear to fix the firmware!!
Thanks.
