SkyWalker2_D's avatar
Feb 12, 2024
R8000P - Not able to login via Nighthawk App
Hi! Ou tof nothing I have the situation that I can`t login into my router via Nighthawk App. The username and passwort are correct and I changed them already to see if this cause the problem. I...
  • SkyWalker2_D's avatar
    SkyWalker2_D
    Feb 22, 2024
    So finally it is fixed!
    The not working adress reservation was never a problem for me and was not my question here.
    I still use an older firmware and it is working.
    My problem was the missing possibilty to log into my NH app and starting the Home Assistant Netgear Integration.
    I checked the "trusted devices" and it seems the amount of devices was reached. So I had to delete my old mobile phones and the app is starting again and Home Assistant is working well too.
    It seems, I found the solution on my own.
    Many thanks to me!
