SkyWalker2_D
Feb 12, 2024Guide
R8000P - Not able to login via Nighthawk App
Hi! Ou tof nothing I have the situation that I can`t login into my router via Nighthawk App. The username and passwort are correct and I changed them already to see if this cause the problem. I...
- Feb 22, 2024
So finally it is fixed!
The not working adress reservation was never a problem for me and was not my question here.
I still use an older firmware and it is working.
My problem was the missing possibilty to log into my NH app and starting the Home Assistant Netgear Integration.
I checked the "trusted devices" and it seems the amount of devices was reached. So I had to delete my old mobile phones and the app is starting again and Home Assistant is working well too.
It seems, I found the solution on my own.
Many thanks to me!
schumaku
Feb 12, 2024Guru - Experienced User
FURRYe38 wrote:
AH that's IP Address Reservation. Reservations are set ON the router. Static is set ON devices themselves.
Great, considering I have an MR60 - undoubted a router and in router mode - where and how can we put up an IP Address Reservation please? Without, the portforwarding feature is of limited use only. What a mess....
FURRYe38 wrote:
There is a problem with official release FW. There is a beta if you feel you need it.
Most likely new NH app versions will not work with older versions of FW>
Are you talking about a Beta App, pr a Beta for the MR60, or both - to allow an IP Address Reservation (IP-MAC address reservation)?
SkyWalker2_D
Feb 22, 2024Guide
Many thanks to me!
- FURRYe38Feb 22, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
