AZ2196
Sep 10, 2024Follower
R85000
Two R8500 nighthawk routers. Each one located in different states. Each one operates online home equipment such as video cams, heat and cooling, security systems just to name a few. The question is...
Sep 10, 2024Guru - Experienced User
Not sure if AnyWhere Access is supported for the R8500 since it's EoL:
Something to check and see when your local at one of the router locations. See if Anywhere access, if enabled, is seen on the NH app.
