guru1338
Aug 08, 2020Follower
R9000 Inbound Firewall Rules
Searched all over google for articles and videos on how to configure port forwarding and enabling firewall rules to only allow a specific range of IP addresses from the Internet to access an internal...
michaelkenward
Aug 09, 2020Guru - Experienced User
guru1338 wrote:
I finally called Netgear support and they gave me a generic user manual that is not that clear, and it's steps is not matching the interface on my router, even though its for the model of the router that I have.
Is the manual for your device no good?
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
My understanding is that there's nothing you can do with the router's firewall but you can play around with port forwarding.
