DannyLin
Apr 06, 2022Apprentice
RAX120v2 - Remote Management option missing
My RAX120 was dead, and just send it via RMA and got the new RAX120v2. But now there's a problem: The Remote Management option is gone. There's no way to manage my router via the Nighthawk a...
Apr 07, 2022Guru - Experienced User
DannyLin
Apr 07, 2022Apprentice
Thanks for the info. Found it on the Nighthawk app but there’s always a toast message at the bottom saying “Unable connect to your router” that is misleading.
That is why I thought I cannot remotely manage it. (I’m sure my Nighthawk app is the latest version)
- VelcnetApr 14, 2022Aspirant
Can say the same. Nighthawk app always says to me that could not connect to RAX120v2. At the same time it works fine with R9000.
Tried to re-enable Anywhere Access with app connected locally, but issue still remains.
