msrendorg
Dec 01, 2021Tutor
RAX45 Nighthawk app
Just switched from a different Netgear router to the RAX45 AX4300. When I used Nighthawk app before I could see which devices were connected to which of the networks I set up - one 2.4 and one 5. ...
Dec 02, 2021Guru - Experienced User
does it show if you log in through the browser?
msrendorg
Dec 03, 2021Tutor
Yes it does. Thank you. But strange that the android app no longer does that. Quick follow up question - when I log into the router the computer I am using does not show up though clearly I am connected to my network. Is that supposed to be?
- plemansDec 03, 2021Guru - Experienced User
what gateway are you connected to?
Using any managed switches or anything like that?
what ip address is the computer and what one is the router on?
I've never been very impressed with the attached devices list on either the app or browser. It seems like everytime they fix it they then update something else that breaks it again. I've learned not to trust it to much.
