NTCE
Nov 27, 2024Guide
RAX50 V1.0.16.132_2.0.92 - NOT DISPLAYING ATTACHED DEVICES DETAILS PROPERLY
When I am using the Nighthawk App, under the details of the Device Manager of Devices Online...it shows the devices but it doesn't show IP Address even if the device is connected via hard wired conne...
Nov 27, 2024Guru - Experienced User
What mobile device do you have? Android or Apple?
Does this happen across other mobile devices with the NH app?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Has a factory reset and setup from scratch been performed since last FW update on the router?
NTCE
Nov 27, 2024Guide
Hi, I have an Android 13 & 14 and iOS 18... and this happens on All OS environments.
In Android, first loads dashboard, look at devices connected number, then when enter to see devices it shows the new profiled menu and as you inside the device individually you see some details not everything.
In iOS, first loads dashboard, look at devices connected number, then when enter to see devices it shows a different menu, you can go inside individual device and see All details including IP Address, Link Status and etc., but after a bit and you exit back then it shows the new profiled menu and as you inside the device individually you see some details not everything as like Android version.
Very weird and unexplained.
