Draketungsten
Jul 31, 2023Aspirant
RAX54S - Access Control
When I log in to my Rax54 and go to the Access Control function, it tells me that I have to use the Nighthawk App. When I got to the Nighthawk App, it doesn't give me the control I'm looking for. I...
Aug 02, 2023Guru - Experienced User
I don't think the web ui nor NH app support that. You can either enable or disable or block devices by device select only.
