Tara987
Jun 10, 2023Aspirant
RAXE 300 No Access Control
I try to access "Access Control" on my PC it tells me I have to use the NIghthawk App. There is no way to access it on the app (which is such garbage). Called tech support last night they had me upgr...
Jun 10, 2023Guru - Experienced User
Have you factory reset the router and setup from scratch with a wired PC and web browser. Don't use the NH app.
Most of the controls can be blocked using the NH app.
- Tara987Jun 10, 2023AspirantYes we did that last night and it gave me access control on the PC. However today it went away again.
