1yonger's avatar
1yonger
RAXE450 anywhere access does not work using IP Passthrough enabled on AT&T BGW320
I have AT&T fiber through BGW320 device.
I installed RAXE450 and enabled IP passthrough on the BGW320.
Remote access using Nighthawk anywhere access does not work with IP passthrough. No issues locally.
I suspect app cannot see the router with IP passthrough.
Any workaround on this or is this a permanent annoyance with BGW320 (IP passthrough)?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What is the firmware on the RAXE450? Which app? (Android? iOS?)
    In what way "does not work"?
    AT&T seems to have the same strategy as BT in the UK, it supplies gateways that are impossible to configure as users might like. No true bridge mode.
