Retired_Member
Jul 02, 2022RAXE500 mobile app shows Internet Offline
This recently started happening to me last night. I have the RAXE500 since Jan 2022, and haven't had any issues until last night. My TV kept disconnecting from the wifi, my sons Nintendo Switch'...
Jul 03, 2022Guru - Experienced User
What CAT# LAN cable are you using between the router and ONT? CAT6A STP is recommended.
What mobile platform are you using? Apple or Android?
FYI:
Ensure Local Network is enabled on Apple Devices:
Does the Internet LED on the RAXE appear AMBER when this happens?
- Retired_MemberJul 03, 2022
What Firmware version is currently loaded? V1.0.10.82_2.0.39
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Frontier FIOS. The back of the ONT says GPON ONT Model: FOG421What CAT# LAN cable are you using between the router and ONT? CAT6A STP is recommended. I am using CAT6A.
What mobile platform are you using? Apple or Android? Android
FYI:
Does the Internet LED on the RAXE appear AMBER when this happens? All white lights, no amber or red lights.
