PGalore
Dec 11, 2022Aspirant
RAXE500 Speed within Nighthawk app much faster
I'm on 1000Mbps plan and when I run the speedtest within Netgear Nighthawk app on my iPhone that's connected to 5Ghz wifi, I get 930Mpbs down and 47 up w/ 7.0 ms ping. However, when I run the s...
- Dec 15, 2022
The speed test function in the nighthawk app will often use the router itself as the client device, thus you are measuring the speed of the WAN connection to the router, and not the speed of the connection to your smartphone or other devices behind the router.
Dec 13, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
BE sure to install Ooklas installable speed test app on a PC or mobile device. Don't use browsers as they tend to reduce speed results or give inaccurate results.
Also some mobile devices may top out at around 400-500Mbps depending upon there design and support. 2x2 MIMO has it's limits. 4x4 MIMO devices have more capability. Ethernet will always perform better than wireless.
PGalore
Dec 14, 2022Aspirant
Firmware version is V1.0.10.86
We are on NBN HFC in Australia and the modem provided by them is ARRIS CM8200.
ISP is Aussie Broadband. The cables are CAT7.
When I run the speed test on Speedtest app (not browser), I get about 700Mbps when I'm in the same room as the router and drops to 400-500Mbps in my bedroom. But for some reason the speed test within the Nighthawk app always clocks 900+ Mbps, no matter which room I'm in or what time of the day it is. It's like the Nighthawk speed test is measuring the speed when a device is connected with an Ethernet cable to Nighthawk.
