PGalore
Dec 12, 2022Aspirant
RAXE500 Speed within Nighthawk app much faster
I'm on 1000Mbps plan and when I run the speedtest within Netgear Nighthawk app on my iPhone that's connected to 5Ghz wifi, I get 930Mpbs down and 47 up w/ 7.0 ms ping. However, when I run the s...
- Dec 16, 2022
The speed test function in the nighthawk app will often use the router itself as the client device, thus you are measuring the speed of the WAN connection to the router, and not the speed of the connection to your smartphone or other devices behind the router.
PGalore
Dec 14, 2022Aspirant
Firmware version is V1.0.10.86
We are on NBN HFC in Australia and the modem provided by them is ARRIS CM8200.
ISP is Aussie Broadband. The cables are CAT7.
When I run the speed test on Speedtest app (not browser), I get about 700Mbps when I'm in the same room as the router and drops to 400-500Mbps in my bedroom. But for some reason the speed test within the Nighthawk app always clocks 900+ Mbps, no matter which room I'm in or what time of the day it is. It's like the Nighthawk speed test is measuring the speed when a device is connected with an Ethernet cable to Nighthawk.
Razor512
Dec 16, 2022Prodigy
- PGaloreDec 16, 2022Aspirant
That's what I suspected. So instead of connecting my device with an Ethernet cable to the router to measure the speed, as often ISPs tell you to do, I can just run the speedtest on Nighthawk app to see the maximum speed I'm getting.
- Razor512Dec 16, 2022Prodigy
Pretty much, though there are things I have not had a chance to personally rest due to a lack of a fast enough connection. Since the router is using its own CPU to run the speed test application, i am unsure of if it will have a CPU bottlenecks if attempting to perform a speed test on a faster connection such as a 2Gbps connection. Beyond that,it shouldn't have much trouble with a 1 gigabit connection.
- PGaloreDec 18, 2022Aspirant
Interestingly, at 7:30pm on Sunday, I got around 700 Mbps over wifi on my iPhone, but the Speedtest on the Nighthawk app was around 300 Mbps on average. I tested 5 or 6x.
