drewestes2531
Dec 27, 2020Aspirant
Admin Password quit working RBK20W
My Admin password quit working and will not let me in. I have gone to the Netgear help and when i go to the websites they recommend I get errors that the webpage cannot be displayed. I have tried ...
michaelkenward
Jan 02, 2021Guru - Experienced User
drewestes2531 wrote:
The message I recieved when entering my admin password was that it was not correct with prompts to take you to Netgears website.
I doubt if that is a "Netgear website", as in something out there on the Internet. It is more likely to be the graphical user interface (GUI) on your router. (Tell us the address of that "website" and you might get more help.)
My internet provider is Google, but when I set it up originally I turned the Google wireless off.
I didn't know that Google was also an Internet service provider. (It isn't where I live.) Do you pay Google for your Internet? Or do you mean that you have a Google device that connects you to the Internet?
Is there a Google box of some sort sitting between your RBK20W and the Internet? If so, turning off the wifi does not disable the router bit.
So I powered my Netgear modem off and restarted the system figuring since it isn't working and it was ready to replace it everything came baack on line, I looked at my app on my phone and it took my admin password and had worked fine since.
What is this Netgear "modem"? Your message is about the RBK20W. That isn't a modem. Is there another Netgear device that you haven't told us about?
My guess, based on incomplete details of what is at your end, is that you
have two routers on your network and that is the cause of your grief.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
The fix was to power down the Netgear modem.
To me this confirms my analysis. If this happens again, here's the solution.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If you have problems in the future, do tell people about everything on your network. The sudden arrival of a "Netgear modem" means that you missed out an import link on the chain.
drewestes2531
Jan 02, 2021Aspirant
Please excuse my terminology error in my earlier note. I meant router not modem.My wifi router is the RBK20W.
On the app on my Apple I phone when I would try to open the app, is when iit was asking for my admin password. Since my password would not work the Netgear app gave me two options Forgot password or reset the Netgear router. As mentioned earlier restting the system was not my first option. When I chose reset admin password it took me to a Netgear help webpage with routerlogin.com or routerlogin.net. When I would enter those pages is when I got the error message.
I have tried to recreate the incident since everything is working now and Icannot recreate it or i would take a screen shot and attach it. I can access the website now.
(maybe something to do with the router needing to be started?)
We we live we have Google Fiber as our internet and television provider. Google admits the their wifi routers are lest than okay and recommend you get your own wifi router. This is very common in our area and Google support assists you in turning off their wifi as no not interfere with the Netgear or what ever other router we purchase.
I was trying to let you know everything but called my router a modem by mistake.
