LorneAv
Oct 23, 2015Tutor
cannot sign in to openDNS account to set-up parental controls using NETGEAR Genie
Hi, I am trying to use NETGEAR Genie Parental controls and when I attempt to login to my OpenDNS account, I get the following error message: "There was an error signing, in please make sure you're ...
TonyWilath
Sep 17, 2016Guide
I currently have a Netgear D7800 on firmware 1.0.1.10 and my Netgear Genie version is 2.4.26 (both most recent versions). All has been working well until today when suddenly the parental control feature in netgear genie wont accept my username/password for my opendns account. I have changed the password on the opendns site and can confirm both before and after my password change I was able to login to the opendns website directly so this means there is no issue with my username and password.
Its almost as if the netgear genie is not passing this through or communicating with opendns.
As a result my parental controls are not working. I bought this top of the range route for only that purpose and now its not working.
It is now Sep 2016 and the last response to this was in 2015 in the forums and this still doesnt seem to be solved.
TonyWilath
Sep 17, 2016Guide
I should also add that I am using a 15 character password and have rebooted the router and PC multiple times. I have the latest version of firmware and netgear genie.
- DexterJBSep 18, 2016NETGEAR Moderator
Hi TonyWilath,
1. Have you tried logging in using another device (smartphone, tablet, another computer)?
2. Did you setup your account through the NETGEAR Genie or did you already have an existing OpenDNS account?
3. Are you able to login through https://netgear.opendns.com/sign_in.php?
Dexter
Community Team
- TonyWilathSep 19, 2016Guide
Hi Dexter
I just thought I would let you know that this issue manifested shortly after I upgraded the firmware to 1.0.1.10. In regard to your questions:
1) When I log in using the Genie app on my Samsung S6 Galaxy it does the same thing (i.e. wont log in) on the first attempt. When I retry it then logs in (this happens every time I repeat this exercise and always works on the second go). Once I am in and I enable Parental Control I go to into the device map and try to set the individual devices and it wont let me do so. From what I have read on the Opendns forums this is an issue with the Netgear firmware and compatibility with the Genie software (i.e. this latest firmware is not fully compatible with the latest Genie software). This would also explain the buggy behaviour I get from using the Genie app from both my Samsung S6 and my Windows 7 PC. It also aligns with the fact I just recently upgraded the firmware on the router.
2) I had and existing opendns account. However this cannot be the issue as this account has been working properly on this router as far back as March this year (2016) with no issues.
3) Yes I confirm am able to login using my credentials at the site address you provided.
I would like to know if there is going to be a new release of the Genie app soon and if not is it possible to roll back the firmware version on my router? If so where can I get the previous release of the firmware?
- DexterJBSep 19, 2016NETGEAR Moderator
Hi TonyWilath,
Thank you for responding. Let me check on this.
1. Have you done a factory reset after updating the firmware? If not, please do so.
2. Can you please provide a link to the OpenDNS forum discussing the issue?
3. You can find the previous versions of the device firmware using the link below.
https://www.netgear.com/support/product/D7800.aspx?cid=wmt_netgear_organic#download
Dexter
Community Team
