jgg1950
Aug 21, 2024Apprentice
Mr70
If I uninstall nighthawk then reinstall it will it pickup all devices again?
jgg1950
Sep 17, 2024Apprentice
Sorry for late response,Your questions listed below.
1. Yes for instance my Samsung S24+ all functions work ie its online internet.
2. Yes
3. Yes
4. V1.0.3.34
5. New version not found on Netgear website.
6. Arris surfboard S33.
7. Arris connects directly to Mr70.
Hope thi helps.
Thanks
2. Yes
3. Yes
4. V1.0.3.34
Hope thi helps.
Thanks
sonofgohan
Jan 12, 2025Aspirant
Uninstalling and reinstalling the Nighthawk app typically does not automatically reconnect all devices to your network. You may need to manually reconnect each device after reinstalling the app, as the app primarily serves as a management tool rather than a direct connection facilitator.
- jgg1950Jan 12, 2025Apprenticesonofgohan, thanks for reply, It discovers all my devices but some show offline but they are online. Each time you you start the app it shows a different set of devices online/ offline. Ones that were offline are now online ,
