Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
Retired_Member
Sep 18, 2021jbclavaud, What version of nigthhawk app are you running?
I'm running 2.11.0.11 on my MK63, under Device Manager, i can see all 25 devices that connected to 2.4ghz and 5ghz.
If i tap MR60 i can see both MS1 and MS2 connected to MR60.
If i tap MR60, it shows all devices that connected to MR60, 5 devices connected to 2.4ghz and 8 devices connected to 5ghz.
Everything seems to work,
The problem is that if i tap either MS1 or MS2, there is 0 device conneted.
So far i can only depend on the Device manager to see which device is on/connected.
jbclavaud
Sep 18, 2021Tutor
My iOS app version is 2.11.6.0
I had the same issue with the previous version as well that’s why I decided to try a new account.
- btv_94Sep 19, 2021Guide
New version = same problem.
Current connection: both MS1 and MS2 connect to MR as wired backhaul. I get full speed test everywhere inside the house (400-430mbps). This is where nighthawk app has problem.
I also tried connect both MS1 and MS2 to MR as WiFi/wireless backhaul, but my speed test at MS area can only get around 140mbps (1/3 speed) and yet the nighthawk app works without any problem. Both MS show all the devices that connected.
For now I'm just going to wait and see if newer version will ever solve the problem.
Thanks,
- MCharlestonOct 14, 2021Aspirant
Did the new account fix it? I have tried a few things, but still can't see the Device Manager in the app.
