JoeM11
Mar 03, 2021Star
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version. Probably an App issue but they need to get this fixed.
- Mar 05, 2021
Hi JoeM11,
Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
Christian
michaelkenward
Mar 11, 2021Guru - Experienced User
I think you'll find that there are quite a few bugs in the latest iOS app, as has been mentioned here quite a bit in recent weeks, if not longer.
Here's a taster:
Search - NETGEAR Communities – iOS nighthawk app
Sort by date. Not a pretty sight.
You have added a new bug. Unlike the issue you see, which seems to be mostly cosmetic, some of the bugs really do hinder the operation of the iOS app. You just have something annoying that does not make sense. (The app should never report firmware issues for cable modems, unlike DSL modems, because it can't do anything about them.)
Christian_R has already told you that they have passed on your report. Don't hold your breath waiting for action. The update process seems to take time.
JoeM11
Mar 11, 2021Star
Thanks...really stinks that I can’t use the tool...it was one of the main reasons I got it
- michaelkenwardMar 11, 2021Guru - Experienced User
What do you want to use it for?
- JoeM11Mar 11, 2021StarManaging bandwidth by device...locking down my kids...etc
Yes. Those functions are the real victims of this iOS "update".
You can do some of this stuff with a browser when you are "on site".
As a stop gap, have you looked into doing this with a mobile browser on your mobile?
The latest Nighthawk app no longer supports standard (free) Parental Controls, only the paid for Circle.
Parental Controls still work but you may have to to manage them with the desktop genie for your operating system.
On a mobile device you can use a browser and login to your Parental Controls account at opendns.
Manage things from there.
- JoeM11Mar 15, 2021StarIs anyone else having this issue??
- bluehaze911Mar 25, 2021InitiateYes! I have the same issue & I'm on Android, so it's not just an ios issue. I bought the C7800 to replace an older model which I was able to see in the app. I'm on Comcast as well & have its latest version.
- JoeM11Mar 25, 2021StarThese guys need to get this fixed!!
- JoeM11Mar 26, 2021StarAnother Nighthawk update with no fix for this issue...not sure why this is not a priority for these folks...to pay $300+ and not be able to use the app is very wrong.
- JoeM11Apr 16, 2021StarUpdate: still not fixed, no communication, not priority for them...very poor experience. Someone over there should lose their job for allowing this to be a product unsupported.
- JoeM11Apr 22, 2021StarAnother update, another disappointment...issue still not resolved
- JoeM11May 19, 2021StarAnother month has passed and Netgear has still not fixed the compatibility issue with its App. Can anyone get this done? Miserable customer experience here!
- JoeM11May 21, 2021Star
- randomPstMay 27, 2021InitiateAm getting the same screen, trying to use Nighthawk app. Everything up to date.
- JoeM11Jun 07, 2021StarAnother App update, another disappointment…these guys are a joke and just don’t care that we can’t use a tool that we all paid for when we purchased. Not sure why someone in management doesn’t step up and get this fixed today!!!!!
