JoeM11
Mar 03, 2021Star
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version. Probably an App issue but they need to get this fixed.
- Mar 05, 2021
Hi JoeM11,
Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
Christian
bluehaze911
Mar 25, 2021Initiate
Yes! I have the same issue & I'm on Android, so it's not just an ios issue. I bought the C7800 to replace an older model which I was able to see in the app. I'm on Comcast as well & have its latest version.
JoeM11
Mar 25, 2021Star
These guys need to get this fixed!!
- JoeM11Mar 26, 2021StarAnother Nighthawk update with no fix for this issue...not sure why this is not a priority for these folks...to pay $300+ and not be able to use the app is very wrong.
- JoeM11Apr 16, 2021StarUpdate: still not fixed, no communication, not priority for them...very poor experience. Someone over there should lose their job for allowing this to be a product unsupported.
- JoeM11Apr 22, 2021StarAnother update, another disappointment...issue still not resolved
- JoeM11May 19, 2021StarAnother month has passed and Netgear has still not fixed the compatibility issue with its App. Can anyone get this done? Miserable customer experience here!
- JoeM11May 21, 2021Star
- randomPstMay 27, 2021InitiateAm getting the same screen, trying to use Nighthawk app. Everything up to date.
