JoeM11
Mar 03, 2021Star
Nighthawk app same "firmware not updated" when it is the correct version
I am unable to connect although I have the correct firmware version. Probably an App issue but they need to get this fixed.
- Mar 05, 2021
Hi JoeM11,
Thanks for confirming. Your device's firmware is up to date and you should be good to go. I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.
Christian
JoeM11
Apr 16, 2021Star
Update: still not fixed, no communication, not priority for them...very poor experience. Someone over there should lose their job for allowing this to be a product unsupported.
JoeM11
Apr 22, 2021Star
Another update, another disappointment...issue still not resolved
- JoeM11May 19, 2021StarAnother month has passed and Netgear has still not fixed the compatibility issue with its App. Can anyone get this done? Miserable customer experience here!
- JoeM11May 21, 2021Star
- randomPstMay 27, 2021InitiateAm getting the same screen, trying to use Nighthawk app. Everything up to date.
