TristenB34
Jul 28, 2022Follower
Nighthawk app
My app doesn’t let me connect with the QR code it says it’s connecting then doesn’t let me continue
CD_router_888
Jul 29, 2022Guide
Hi TristenB34 ,
It is a known issue and NTGR had fixed it, will release the new version app after 8/3...
For now you can use either ways below to work around it.
- Fresh install APP --> Sign in SSO --> Don’t kill the app and re-launch it --> QR code scan --> tap Continue button --> Can finished the install setup then go to the dashboard
- Fresh install APP --> Sign in SSO --> Don’t kill the app and re-launch it --> Set up NH manually --> Can finished the install setup then go to the dashboard
