BretD
Mar 29, 2018Administrator
Update to the latest Nighthawk App (formerly NETGEAR Up) WiFi Simplified
“NETGEAR Up” is now the “Nighthawk App” with all the same great features and much more to come!
The Nighthawk® App makes it easy to set up your router and get more out of your WiFi. With...
Pntsharma
May 31, 2018Guide
Kindly add a toggle for LED lights to be controlled. Cheers!
- BaJohnJun 10, 2018Virtuoso
... and now for something positive.
I have the R8500 and I was interested in the App as I was wondering whether my 'bad link' in the chain was my WiFi in the house or maybe the feed into the house.
I normally get 100 - 120 Mbps on a good day and the PC setup correctly, yet my Internet supplier says the line is 200 Mbps.
My PC (main computer) for complicated reasons which I will not go into here, is a long way from the Router and through 2 sets of cavity walls at an angle. The signal at the PC is listed as 100% or near most of the time.
After installing the App on my phone it worked first time and the speed test gave a download speed of 215 Mbps, which it has also consistently given since installing it.
Hence the App has helped me identify the WiFi link internally as the restriction, which is as I thought.So some good news.
From the App 'About' button it says App Version 2.1.3.3, Firmware Version 1.0.2.122, Model Number R8500.
