Cadmuslabs
Mar 14, 2018Follower
Ready Cloud App NOT WORKING
I have an iPhone 6 Plus running iOS 11.3 I downloaded the ready cloud app and installed it. I set it up to backup my photo library to my USB hard drive connected to my nighthawk router. It is fully se...
DexterJB
Apr 10, 2018NETGEAR Moderator
Hi Cadmuslabs,
Welcome to the community!
1. What is the firmware version of the router?
2. What is the app version that you have installed?
3. Does the issue persist when using another device (iOS, Android)?
4. Have you tried resetting the router?
Dexter
Community Team
SharathB
Apr 11, 2018Aspirant
I have been trying to find solution for this for past one year. Unfortunately it does not look like Netgear wants to even fix it. The app shows as if it is uploading. But when I go and check the folder the photos are not there. I have even tried to format my HD. Still the problem persists. All firmware etc. are up-to-date.
