NrAtWork
Oct 19, 2017Guide
ReadyCloud V2.0.0,(2027) on iOs11.0.3 not doing media backup on R7000
I have set up my HDD in RAID config and used R7000 router's Advanced>Readyshare>ReadyCloud to use my HDD to back up my PCs and photos and videos from mobile devices. Everything worked great and from ...
YeZ
Oct 20, 2017NETGEAR Expert
Can you unregister and re-register R7000 to ReadyCLOUD in the router web page to see if that solves the issue?
- NrAtWorkOct 20, 2017GuideThanks YeZ for your help:
I did this step yesterday before posting on community board. I unregistered the router and I also deleted the ready cloud app also from all phones and then registered r7000 again and then reinstalled the app- but the problem is still there: I still can’t do any media backups from my devices- JeremyDEOct 22, 2017TutorI’m having the same problem. It just shows that it’s uploading my media but it is not working. I’ve tried your recommendations and it’s still not functioning. Help.
- gazpadOct 22, 2017AspirantDitto. It seems related to the IOS 11 update. The App looks like it has an updated skin but same old functions, with exception that it’s found loads of media to back up but won’t start backup process.
Note, I can access my readynas without issue. I am having this problem accessing a Readynas 214
- NrAtWorkOct 26, 2017Guide
I did this step yesterday before posting on community board. I unregistered the router and I also deleted the ready cloud app also from all phones and then registered r7000 again and then reinstalled the app- but the problem is still there: I still can’t do any media backups from my devices- jerome60Oct 27, 2017Aspirant
same thing happened to me finally erased router and started all over from square one and same problem also using ios 11
- JeremyDEOct 27, 2017TutorDid erasing and starting over fix the problem?
- Niels72Oct 28, 2017AspirantReadyCLOUD needs a update fot ios 11.03 for me it’s not possible to send fils to wij hdd. It’s horrible log in log out to find mij files. Netgear ReadyCLOUD can’t Integrated with my iOS. I hope there’s soon a update
- dhamsherOct 28, 2017Tutor
I think that the issue may be with the new HEIC filess that come with ios11. Netgear, any timeline for a fix?
