Catboat
May 15, 2019Guide
Readyshare is accessible in windows but not through Nighthawk app
The readyshare drive shows in windows 7 and 10 but not with the nighthawk app (apparently the Genie app is not compatable)installed on an iPhone 10 and with blue stacks android emulator on windows 1...
schumaku
May 15, 2019Guru - Experienced User
Not sure why you mention the Android emulator for Apps - regardless if using iOS or Android, the Nighthawk App does not allow the simple ReadyShare access and file/folder transfer with two simple tabs (local, remote) we're used to from the Netgear Genie Apps.
Even the ReadyShare App does not have a functionality similar to the Genie App ReadyShare access.
- CatboatMay 16, 2019Guide
Is there an app that will allow access to the readyshare drive since the Genie is not compatable? The mention of the andriod emulator was just to show what I am running the app on and if it was a factor in the issue I am having
Even the ReadyShare App does not have a functionality similar to the Genie App ReadyShare access.- schumakuMay 16, 2019Guru - Experienced User
com.netgear.readycloud
https://play.google.com/store/apps/details?id=com.netgear.readycloud- CatboatMay 17, 2019Guide
I appreciate your help, but I'm thinking that this app is meant to connect for a Readynas? I do not have a ReadyNas I am using a Toshiba 500 gb 2.5" external.
