Catboat
May 15, 2019Guide
Readyshare is accessible in windows but not through Nighthawk app
The readyshare drive shows in windows 7 and 10 but not with the nighthawk app (apparently the Genie app is not compatable)installed on an iPhone 10 and with blue stacks android emulator on windows 1...
schumaku
May 18, 2019Guru - Experienced User
michaelkenward wrote:
I know nothing about the iJunk app. I do know that its apps sometimes lack features that work on Android devices.
Lot of App limitations were caused on both Android and iOS from the initial full data isolation ideas.
The biggest missing feature in the ReadyCloud app is the side-by-side view (in two tabs) for the local and the remote storage available in the Genie App, but oddly not in the (comparably poor and aged) ReadyCloud App.
Catboat
May 29, 2019Guide
I still can not connect to a external HDD connected to my nighthawk
- schumakuMay 29, 2019Guru - Experienced User
Catboat wrote:I still can not connect to a external HDD connected to my nighthawk
Uh...now you confuse me. You wrote in your initial post:
Catboat wrote:The readyshare drive shows in windows 7 and 10 but not with the nighthawk app...
So you can't see and access the HDD connected at all?
- CatboatMay 29, 2019Guide
Within my home network I can see the readyshare drive in windows, but outside of my home network is what I was hoping to be able to do, but that doesn't seem to work
- michaelkenwardMay 31, 2019Guru - Experienced User
It isn't obvious to me that you have set up and configured ReadyCloud through a MyNetgear account.
There is a manual for the R9000 somewhere at the end of this link:
>>>> Nighthawk X10 R9000 | AD7200 Smart WiFi Router| NETGEAR Support <<<<
See the section Remotely Access a USB Device Using ReadyCLOUD.
Maybe you have done all that, but it doesn't come across in your messages.
Did you even try to install the app as schumaku suggested?
I have just noticed that we don't even know which firmware you have on the R9000.
