stanfrench
Nov 04, 2017Luminary
ReadyShare Vault Backup Engine Failed
I can no longer back-up my Desktop PC using ReadyShare Vault. I have a Netgear Nighthawk AC2350 (R7500) wifi router and a Western Digital My Passport 2 TB portable hard drive attached to the router. ...
DexterJB
Nov 08, 2017NETGEAR Moderator
HI stanfrench,
1. What is the firmware version of the router?
2. What version of the ReadySHARE Vault program do you have installed?
3. Is the laptop also using the ReadySHARE Vault program?
4. Is the laptop also backing up the same amount of files as the desktop?
5. What is the operating system of the laptop and the desktop?
6. Have you tried re-installing the program on the desktop?
Dexter
Community Team
DexterJB
Nov 12, 2017NETGEAR Moderator
HI stanfrench,
Please try installing the latest version (version 7.0) of the program from the link below.
Dexter
Community Team
- stanfrenchNov 12, 2017Luminary
Thank you Dexter, I tried that (v7.0.1.100) but same problem. It gets to about 350 items and then stops. When I open the dashboard, it still says "Backup Engine Failed". Do you know if its possble to install the lower version? I was working ok. Or I can keep trying to troubleshoot this one. Cheers.
- DexterJBNov 22, 2017NETGEAR Moderator
- dhakerDec 20, 2017Aspirant
I am having the same trouble trying to backup a Dell Laptop!!
- stanfrenchDec 20, 2017Luminary
The solution for me was to install an earlier version of Netgear ReadyShare Vault. But you need their assistance to get it.
- shandyjt2Mar 13, 2018Aspirant
It appears to be backing up for a while andthen ends with "Backup Engine Failed".
Read a few threads here and upgraded my software and firmware.
Any help is appreciated.
I saw some saying iinstall and older version but haven't been able to find older software.Hardware Version R6900
Firmware Version V1.0.1.44_10.0.28
GUI Language Version V1.0.1.44_2.1.38.1- stanfrenchMar 13, 2018Luminary
Here is the link I was given that helped me solve my problem with the engine failure.
http://files.netgear-support.com/go/?a=d&i=RlgLv14wfc
Hope it works for you. I've since moved to Mac so i no longer use ReadyShare (only for Windows). I guess that permanently solved my problem...and others.
