stanfrench
Nov 04, 2017Luminary
ReadyShare Vault Backup Engine Failed
I can no longer back-up my Desktop PC using ReadyShare Vault. I have a Netgear Nighthawk AC2350 (R7500) wifi router and a Western Digital My Passport 2 TB portable hard drive attached to the router. ...
DexterJB
Nov 12, 2017NETGEAR Moderator
HI stanfrench,
Please try installing the latest version (version 7.0) of the program from the link below.
Dexter
Community Team
stanfrench
Nov 12, 2017Luminary
Thank you Dexter, I tried that (v7.0.1.100) but same problem. It gets to about 350 items and then stops. When I open the dashboard, it still says "Backup Engine Failed". Do you know if its possble to install the lower version? I was working ok. Or I can keep trying to troubleshoot this one. Cheers.
