stanfrench
Nov 05, 2017Luminary
ReadyShare Vault Backup Engine Failed
I can no longer back-up my Desktop PC using ReadyShare Vault. I have a Netgear Nighthawk AC2350 (R7500) wifi router and a Western Digital My Passport 2 TB portable hard drive attached to the router. ...
stanfrench
Dec 21, 2017Luminary
The solution for me was to install an earlier version of Netgear ReadyShare Vault. But you need their assistance to get it.
dhaker
Dec 22, 2017Aspirant
I would also like to install a older version of ReadyShare Vault and have searched the sight but can't find a older version. Any help would be appreciated.
- stanfrenchDec 22, 2017Luminary
Here is a link to a lower version that worked for me when I had the "Back-up Engine Failed" issue:
http://files.netgear-support.com/go/?a=d&i=RlgLv14wfc
Good luck!
- romalleyMar 10, 2018Initiate
Readyshare Vault is not working. Always says "backup engine failed." I have downloaded the lastest program and firmware for my router. I'm not sure what else I can do.
- dhakerMar 11, 2018Aspirant
I am also still having the same problem. When I try to download the earlier version It says I need additional information to download the software.
